Slick Willy
Well I had the slave cylinder go down on me. It was a easy enough fix, while at it I went ahead and replaced the master cylinder and line. Figured I would be better off in the long run. After bleeding the system off to my surprise I still had no clutch. I double checked my work and have found my clutch release lever has a lot of play. Can my throwout bearing and clutch be stuck and do I need to pull the engine to fix this. As i see no way of doing it unless I pull it. Any help and input would be great thanks.
Hi Guest!
