sim
Hi
Trying the floor jack method
I have made all the disconnects but engine still not free to lift so i missed something
Motor mounts were released at body 2 bolts each
propeller shaft been removed
Tranny bolts at cross member are out one on each side
exhaust and carbs are off. Ground wire is off. Speed cable still attached but will take care of that.
Starter motor not been touched but cable been removed
Hydraulic line to slave disconnected
wire to gen are off. battery ground wire is off.
I think that covers it.
When using the floor jack I get about 8 inches high but the front of engine has only moved 1/2 inch. I know the springs have to unload but I am sure I got to that point and did not get another 1/2 inch
any suggestions?
Thanks
Sim
any suggestions?
Thanks
Sim
