I've removed TR engines before, but since this time the engine seems a bit rusty in places, it occurs to me I might ask: Are the two lifting points (one being an eye hole/loop on the back of the front engine plate, and the other being that strap iron piece under bolted the rear-most head bolt) pretty safe to use without fear of one of them breaking? Is it totally unheard of for one of those to break?
Also, due to lack of room this time I plan to pull the engine with the hoist coming from the side of the car (over the fender) and not from the front. Any feeling I'm asking for trouble?
Final question. About removing the transmission from the engine. Do any of you folks pull and carry the transmission away by yourself? With the OD I think the weight is at least 95 pounds. I pulled mine off the engine and its' sitting neatly on my floorboards. I'm just curious if I'm being a wimp calling my son for help getting it from there onto my workbench. Do you guys just breathe deep and pick the thing up solo?
