pulling dents out of an exhaust pipe?
10musketeer
Anyone know any tricks to pull dents out of an exhaust pipe? I have a pretty good size dent where the front bend is under the engine where the p.o. met a curb. Is it possible to drill a hole and then pound the dent out using an L puller and then patch the hole, or is the metal too hard? Is this something a muffler shop can do on the car without too much difficulty?
Maybe a temp solution you could weld a bolt into the center of the dent, then pull it out with a slide hammer.
Two seasons ago my father-in-law ran his Formula-Vee off the track and two of the header pipes (that ran under the frame rails) were nearly flattened. We didn't have time to make new pipes that season so I rigged up a fix.
I took a 1" thick disk of scrap aluminum and bored a hole through it the size of the pipe OD. The disk was then split with a bandsaw so I had two half-disks. I clamped one in a heavy vice and rested the deformed pipe in it. I held the other half-disk by hand while I struck it with a five pound hammer. Repeated hammer blows with frequent repositioning of the pipe got it nearly round again.
While this worked... it would be harder to employ on a curved section of pipe. In your situation, cutting out the damaged section and welding in a new bend would probably be easier.
Thanks for the info. I think I'll just cut and weld- but I do think the idea of welding a bolt and using a slide hammer is interesting. I wonder how much getting the dent out will help. I'm probably loosing 1/2 the diameter and while I know I won't pick up 20hp, I'm sure it'll breath better.
