A
Americanshine
Thought I would offer up several suggestions about the clay bars, as I do use them quite often. I have been getting alot of complaints from people who have tried to use the clay bars. Not mine, but others. I usually get these complaints when I am working at Car shows. I find that the public is misinformed or have not been instructed in the proper use of the clay bar.
First off, I do not care weather you purchase my clay bar or use any of my competitors. I want you to get the FULL Expierence of the clay properly.
Second, the clay bar is for surface contamination removal. It will not take paint down, like when you use cutting compound. The clay bar is ment to takle tree sap, overspray, smog, grit grim or any contamination on top of the paint.
When using the bar, I always set it in the sun, or throw it into a bucket of WARM water, too make it easier to work with. The very first thing you should do is wash off all the loose dirt off the vehicle with a good sampoo. Then do not bother to dry the car off.
Now, you want to use a slightly soapy spray bottle and take the clay bar and flatten it out to be used in the palm of your hand. Spray down some soapy water and using a firm even pressure, apply the bar in large figure eights. Do sections so that you can feel the difference before and after, careful not to let the area you are working get completely dry. While using the bar, fold any contamination into the bar coming up with a clean surface to work with. You can mold the bar to get into those hard to ge areas without "BURNING" a edge. Remember, the bar will not take down the paint, but it will remove the contamination. After doing the entire car with the bar, I usually give the car a quick wash just to wash off any residue. You should get at least 10 time usage out of a bar. I have used the same bar on as many as 15 cars myself. THe only way to trash a bar is if you drop it. DO NOT DROP CLAY BARS!! They become usless for the simple reason that it will pick up any gritty substance on the ground and then be ground into you paint resulting in severe scratching!!
Again, the bars are very safe for the eunthsiast when used properly. I just find that most people who are sold a clay bar are not instructed properly on its use.
Now it is time to put a good carnauba wax on you paint for maximum protection.
Whether you use clay magic, meguires, bar concepts, mothers, eagle one or American Shine. Just be sure you use it proplerly. I am here to be but a servant in automotive cleanliness. It does not matter to me who's you use, just use it properly.
