As for your first post (2 above)-
if you use a catch can then don't use the PCV valve, it won't do anything if hooked-up this way. It will only work on a "sealed" system.
If you just run a 1/2" line from the front breather to the PCV valve (4-cylinder kind) and then straight to the manifold then it will work.
Otherwise just run a 1/2" line from the breather to the catch-can and leave the fitting on the manifold plugged. The car will still leak oil but you will have a catch-can as a "conversation starter".
Bill
Bill
Hi Guest!
I'm completely and totally confused now....
