angelfj1
Project Update and a Few Questions
As you can see the project has resumed once more. This time to the finish, I hope???
I have a couple of questions regarding drainage of the scuttle vent and battery box. I recall the photos from Don “E” which show the drain out the bottom of the battery box and into a hole in the trans. tunnel.
Does this hole in the cover have a grommet?
I got one of Mark's drain hose kits (see https://www.macysgarage.com/myweb6/Parts/other_tr2_3_parts.htm#TR2/3%20Body%20Drain%20Tube%20Set), but this includes only three short pieces of black plastic hose, two for the drains in the boot and one for the battery box.
How is the sump under the vent lid drained? Since I have the same hole (it has a rolled edge) in the bulkhead, do I drain the vent out the front of the bulkhead?
Or, I believe some cars were plumbed with a brass “TEE” connecting the battery box and vent-drain together and then continuing through the top of the tunnel? If I go this route, I assume that we need plug the hole identified by the arrow?
Finally, does anyone have a photo showing the two drain hoses joined with the “Tee” and through the tunnel?
Cheers,
Tags
Cheers,
Tags
