Re: Blown Head Gasket!
A proper head gasket shouldn't need "extra" torque. A FelPro or Payen should be fine with the increased compression. Shoot HiTack on it and wind it down. I've used plenty of flat top pistons in MGB engines with no cronic problem. You have done the "usual" stuff like check the head/block to insure they're "true" I imagine.
You've a set of 40mm Webers on it, too, right? If the thing is running lean at RPM it can cause some head gasket grief. Usually tho, that holes a piston. UGH!
