Progress
jlaird
Today
Sent carb bodys off to Joe for new bushings, throttle rods, and butterflies. New gasket sets as well.
Aligned front end.
Pulled and replaced exhaust system, I was just not happy with the way it was fitted.
Ha, note that tac is now stuck on about 800 RPM so will have to change out, good thing I have another that seems fine. Chances that two are bad is remote I should think.
Way to jinx yourself!
/bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Jack,
Never had much luck with doing alignments myself. Mind sharing your process?
Oh, easy enough. Bugeye is supose to be dead on plus or minus 1/8th.
Jack up front of car, useing tailors chalk spin wheel and put a mark all the way around each wheel.
Put car back on floor, now measure the distance between the chalk lines, roll car forward half a wheel and measure again.
Adjust and do it again and again till both measurements are the same, close enough.
Move on nothing to see here, hehe.
I like it. It must be right. I use one of those cheap toe in deals. Works good for me.
