jlaird
Walked out to garage, hit the switch and pulled the starter, she ran. Hehe, awful with no exhaust on her, so shut her down.
But Miss Agatha talked to me. She did.
Oil pressure is 55 lbs cold. Ran her for about a min and rough adjusted dizzy even though I need to turn it 180 degrees. Have one carb leaking a bit from the mixture nut on the bottom.
She accelerates well, idles and does not stumble but running very rich hehe, not bad for an eye ball set up.
Started first hit from changing the wires around.
Yeeee Haaaaaaw
Yeeee Haaaaaaw
Hi Guest!
