Progress, engine out
jlaird
Came right out of course. No problems.
Now waiting for parts but got a few other things I can work on mean while.
Nice work, Jack. Y'all should come visit Utah and pull Tunebug's motor while you're at it. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Pulled engine etc etc.
Oil pressure was 60 or so cold then down to 20 running warm and 10 idle.
Have a new pump, no prob. now that I have one that was cut down.
Question concerns old pump.
Has a lot of wear that I can see on the outside of the outer pump part where it rubs against the housing, both sides and circumference.
For my education, what is acceptaple for tolarances?
I expect between the circular part of the pump and the case is over .010 can get that one in but would need a wire guage to really tell.
Yep going with the new one of course but refuse to take it apart therefor the question.
Thanks all
I thought the workshop manual detailed the pump tolerances? 0.010" seems a bit "wide" IIRC.
I saw none in the manual Doc. Oh wait let me look again. Noop, don't see anything. But this one is toast. Walls and back and front internaly is like a mtn range. It is really eaten up. I bet it is an orginal from the factory.
Haveing a heck of a time getting the backing plate on, just will not fit. going to a bit of grinding at one edge of the plate where the crank shaft comes through, think the plate might be just a bit off center for this new pump. The small amount I seem to need should not effect bolting it on.
What is the material, i.e. are we dealing with: aluminum rotors and body, aluminum rotors, steel body, steel backing plate, etc.
There may be no mention of specific freeplay/sizing in the manual, but engineering rule of thumbs can apply to general sizing on pumps, rotor to body, body to back plate, etc. Just wanna find out the materials before I give you what I know; as aluminum is more "spacious" than steel or iron for thermal expansion..
Years ago, Melling used to have available a general sizing chart recommendation for rotor depth(gallons per hour flow) and freeplay sizing(for pressures built). But I doubt it's available anymore. Smokey Yunick, Grumpy Jenkins did a bit of research on oil pressure and flow. You might find interesting the info via a little web searching on their info.
hth. but let us know what materials the pump is made of.
Got that sucker now, had to take another 1/16 inch or so off of each or the oil pump ears. I would guess that the factory that made the backing plates did not get the can exactly centered.
So much for quality control, however it did fit with the orginal oil pump so guess I best shut up.
I have two, one unmodified and one where the edges of the case where the bolts
go through are cut down. Both are same brand both are new.
There is no way that pump will fit under the backing plate I have. The pump is
just too large for the cut out where the tin can is soddered on.
What the heck, am I stupid or something in my old age. This is not rocket
science.
Anyone else put a new 948 pump in lately and where did you get it. OR OR OR do
I have a backing plate from something else????? the tranny bolts up to it ok.
Pump body is alum, roter and the outside circular part that the roter drives is steel.
Alum lookid like mountains, very scored, might have been run dry at one time even. Or maybe just old.
No question in my mind that the old pump is toast and clearances are too large, quite worn except for steel to steel.
New pump in now so hopefully all is well now that I know how to modify a new pump to fit.
Quick pic for those that like em.
Lookin' at all them metal shavings makes me nervous, Jack!! /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
Yea but it is alum and I will clean up with a good wash.
/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Are you going to check your rod and main bearing clearances with plasti-gauge just to be sure? It may well only be the pump, but it would not hurt to check them while the engine is out.
Noop, they were put up with a mic. Should be OK. If I have further problems I will take the block up to Hap.
In fact as I remember they were stock size, I got a new crank with the body. Part of the package.
You are right I am sure. I have just decided that I am going to take the chance.
Miss Agatha will never get any big miles on her. Just want to be able to run to shows and take pleasure drives with out problems.
