A small project, but a major milestone. Tonight after work I fitted the driveshaft, and put the Tunebug back on his wheels briefly to make sure all was working as expected. For the first time in well over a year the engine is now connected to the rear wheels!
I used the masking tape trick and with a fair minimum of fuss got the splines lines up and everything connected.
<span style="font-style: italic">Driveshaft in place</span>
It was nice to roll the car in gear (with the spark plugs out) and watch the crank pulley move around.
<span style="font-style: italic">Testing the connections</span>
Making good progress now, and checking things off the list. Next up is the fuel system -- I need to install the new electric fuel pump and pressure regulator and get everything wired in and plumbed up. Then it's on to the engine ancillaries and starting up!
