My night of inspiration last night seems to have worked. I got my motivation going tonight and spent a few hours out in the garage. Got the old axles and hubs out -- used the reverse-the-brake-drum hint and it worked just fine. Had to grind out the inside of the old drum I was using, and then all worked swimmingly.
I've decided to start with the rear end, and work forwards. First is rear diff swap (to a 3.9) and a change to the later style rear brakes. Then reassemble the hubs with new bearings and seals. Finagle the parking brake, and I'll have the rear end pretty well buttoned up. Can't think further ahead than that, but it's a start.
One question -- should I reuse the hubs that came off the Bugeye, or use the ones that were on the donor Midget? Is there a difference between the two?
