well, today is going MUCH better than yesterday. will give a fuller report later.
first though, two wire harness questions for 1500 folk.
1. if you look between the coil and the wiper motor, the harness splits into three. the left goes forward to the headlights. the right goes to the coil/ battery stuff. the centre, a thinner line has a 3 prong female end. - what does that end hook up to?
2. If you then look down under the previous pieces, there is a line that has the plug for the oil sender and the brake sender. the line then continues about 2 feet to a male/female double prong - am I correct that this is the left side signal light?
thanks all
thanks all
