G
Hi all,
I recently bought a MGB 1964. Completely restored and revised but never really "finished". Engine looks really good and a lot of parts have been replaced but suddenly I started to get problems today. It had been parked for one week and when I tried to start it it wouldn't. I heard a ticking nice at the right back (fuel pump) and thought my petrol could have ran out. Bought a 5 liter tank at the petrol station and the car started again.
I then drove to a friend who is an expert on Citroen and has his own garage. We put the car on a bench (I don't know the name but I could stand under it /ubbthreads/images/graemlins/wink.gif) and we saw some petrol leaking from the fuel pump and the petrol measurement sensor at the petrol tank.
It was not too bad but of course not good either.
Furthermore the engine was not running too smoothly and there was a filter at one of the petrol hoses (at the back of the front /ubbthreads/images/graemlins/wink.gif) which showed the petrol was not pumped very smoothly and consistently through.
The fuel pump then also suddenly stopped working. We unscrewed the fuel pump, readjusted it, and it worked again. It did not seem to leak anymore either.
Furthermore we adjusted the carburators a bit so it would better run stationary (which did not really work before).
Then we lowered the bench again and I drove off but halfway the engine stopped and would not start anymore. We pushed it back horizontal and after a few attempts the engine started again and we drove the car outside.
There it was temporarily switched off and .. would not start again. 3 guys looking at my engine to figure out what was going wrong. There seemed to be inconstent power from the battery or something (it even looked flat at one point). So we used some kind of machine to charge it a bit and the engine started again. When measuring the voltage however the dynamo seemed to be working without a problem.
After a while we decided to take the chance and drive back home but on the way home to engine did not sound too good (not smooth at all) and the engine stopped two times at a traffic light. The battery seemed to be flat and we had to push the car to get it working again.
After I had parked it at home for a while it started perfectly fine again (first attempt) and the battery seems to have no problems. The fuelpump I can hear however some times (while running stationary) and it then makes a clicking noise. The engine furthermore makes an awefull high pitched sound right in front at the rotating blade.
Hmm long story :S Any good advices? I have to apologise for my English. I am completely new to cars (although I try to read a lot now) and the Dutch terms are already difficult enough /ubbthreads/images/graemlins/smile.gif If you need any clarification on some points please ask!
Hi Guest!
