TR2/3/3A problems getting the engine to run correct
It's hard to know what caused the cam to flatten. In most cases it happens when you install a performance cam that requires heavy springs. All that pressure goes against the cam and lifter, so break in can often be a 50/50 deal. If you can get through the first hour of running the cam will live for years...if not you have metal all through your new engine. Our engines in stock form have very light spring loads...so I doubt that cause any wear.
In your case, I think you may have the same issues many private airplane engines face. If a motor sits for a long period, the oil drips off of the cam and the lobe becomes dry. Corrosion can also cause small pits to form in the cam and lifter. Then, when started it takes a minute for the oil to splash back onto the cam lobes...so for a minute the cam and lobe can gall, leaving little chunks of metal bonded to the surfaces. As you can imagine, galling results in rapid death of the cam and lifter.
You can check the valves for being stuck by carefully tapping them with a brass mallet. The mallet should bounce right back up. If it sounds dull and doesn't bounce well, then the valve is not sliding properly.
I was thinking...normally you do not want the lifters to pull out of the bores, as they are hard to get back in without removing the head. But in your case, if you have a magnet you can pull the lifters out and flip them over so you can check the faces, and even get a glimpse of the cam lobe with a flashlight. That would answer the cam question pretty easily.
If you decide to go down the road of pulling the head, I found the autozone $20 spring compressor, #25220, worked perfectly. A much more expensive c-clamp/vice grip rental I tried would not compress my springs. Based on YouTube and other reviews, I don’t think the Harbor Freight one would have worked either.
I found valve lapping meditative.
Steve
