RAC68
Problem with LEDs in Illuminated Reflector
Today I installed 1156-based LEDs within my rear reflectors to serve as added directional and brake lights. To simplify the task, a power and ground wire was spliced into the corresponding taillight. Initially implemented using low watt high intensity incandescent bulbs, however, due to a stuck-on brake switch, the high intensity bulbs created sufficient heat to begin lens melting.
As an alternative, I decided to replace the incandescent bulbs and chose very low heat 12-volt 1156 LEDs advertised as 1156 BA15s directional and brake light replacements. After installing the LEDs, no light was emitted when the directionals were activated. The LEDs did light when tested using power sourced directly from the battery.
As this is my first use of LEDs, I would appreciate any thoughts and/or suggestions.
All the best,
RAC68 (64BJ8P1)
All the best,
RAC68 (64BJ8P1)
