Don't blame the carbs right off. They say 90% of these issues are more likely timing/electrical issues. I would recommend going through adjusting valves, checking the plugs, wires, distributor internals and setting the points and timing. From your description only, the carbs would be set way too lean so you may want to enrich them to see if that makes any difference for a quick check then you could check the fuel pump to see if it's keeping up.
