I am having problems with the angle drives I have installed on my TR3 since I installed the A-Type overdrive. As can be seen in the attached picture, they are twisting off on the "spring" part of the stem that goes into the overdrive speedometer drive pinion and bearing assembly. This is the second one that did that in just a few months. I have a new speedometer cable and I cut out the transmission tunnel cover to allow a fairly straight flow of the speedometer cable from the angle drive to the speedometer. (Note that I did not use the 96 inch cable nor the original hole in the floor.) I have read that a defect in the speedometer can cause the angle drives to fail, but have not seen what problem that actually causes with the angle drive. The angle drives I'm using came from TRF and they have circlips that hold the angle drive gear covers in place. So that makes it easy to open up the angle drive to see what failed. Is it worth the high expense of sending the speedometer for rebuild without knowing that is what is causing the problem? Or could the problem be with the overdrive pinion and bearing assembly? Thanks for any ideas!
