Problem fitting rear drain tube to inlet manifold on BT7
fishyboy
Hi all,
Following a recent post about rebuilding by HD6 carbs (https://www.britishcarforum.com/bcf...llow-on-questions-from-HD6-carburetor-rebuild) I have been trying to fiit new drain tubes to the inlet manifold on my BT7. I have been able to fit the front one with no trouble, but I have been unable to remove the old nut from the rear one (it just seem to spin round). Off course I now realise that air is getting though the old drain nut and leaning the mixture on my rebuilt carbs.
As a stop gap, untill I can think of a way of removeing the old nut (without having to take the manifold off), I am wondering whether I could block of the hole in the nut and at least allow the carbs to be set up correctly. Is this sensible?
Phil
Keoke
Well if it is spinning around this may suggest the male part has stripped threads. ?
OH Sure plug the hole.
I wouldn't run with the hole(s) plugged for too long. The holes are there for a reason (the BMC beancounters wouldn't have allowed the installation of extra holes if not absolutely necessary). If you're running rich--like cold engine, chokes full on--gas will puddle in the manifold (this is sometimes called 'wall wetting') and you'll either be washing the oil off the cylinders causing extra wear or, worse, could get some nasty backfires and possibly even a fire.
I've started a cold engine, chokes full on, then shut down after a few minutes. There's usually a couple of not insignificant puddles of gas under the drain tubes.
Healey Nut
Get the car up in the air , Reach up underneath with a set of vice grips , clamp onto the stub in the manifold unscrew while pulling and it should come out . Now you can see if the fitting or the manifold is stripped and then decide how to fix it .
John Turney
Hi all,
Did you remove the carbs to get to the rear one? That's what I would do.
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
KVH TR4/4A Fitting New Dash--Problem with Dash Pads Triumph 3
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
jjbunn Stub axle and bearing fitting problem Triumph 12
6 Moss Top Boot Fitting Problem Austin Healey 2
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
