A couple of suggestions from a POR15 fan...if you sandblast, go VERY lightly with medium grit, juat enough to dull the exist finish. Another thing...prep with Metal Ready one day and paint the next, using a hairdryer after the tank is dry on the first day and right before you paint it on the second day. One drop of water will ruin a large spot of the coating and a drop on the brush put back into the can will ruin the can. /ubbthreads/images/graemlins/shocked.gif
And a might as well...do the bottom of the trunk sureface too with whatever POR15 you have leaft over, as it does not keep well once opened. /ubbthreads/images/graemlins/nonod.gif
Good Luck!
Good Luck!
