A friend here is a Weber carb rebuilder, he made up some fittings recently which are hard to source anyplace. A banjo fitting "Tee'd" off a curved pipe for the gas supply to two 40 DCOE's. He asked if we could pressure test 'em for leaks. I cobbled together a fixture using a C-clamp and rubber membrane to block off the banjo, a rubber end cap and band clamp for one end of the long pipe and a hose with an air chuck for pressurizing the "rig". Here's the bit which may be of interest: not using gasoline. Milk was inserted in the fitting as surrogate fuel and pressure was introduced at 28~30 PSI. Milk will flow the same as gasoline. Water will NOT.
My granfar taught me this back when I was a lad.
