Starting to get back to the rebuild- got
a question on the rings regarding the powertune pisons.
Upper ring and center are spaced in the liner at .013-
this should be ok. The center ring has a grooved(??) area on one side-which side up ? Finally the 3rd(oil ring) with the spring tensioner has <.002 space; should this also be .013 ?
The rings spacing placed at 120 degrees apart ?
Thanks Guys,
Harry
Thanks Guys,
Harry
