GregW
That's what I'd do.tahoe healey said:I'm thinking to either draw power form the brown wire side of the fuse box and put a fuse in line (30 amp ok?)
That could lead to all kinds of problems. If you add the lighting system onto the rest of the cars electrical (all the green wires) you'll either blow fuses all the time when you turn something else on. Or the fuse you'll need for normal operation won't blow before the wires in the harness cook.tahoe healey said:or draw form the green wire side which is already fused. Would I need another fuse in line there?
One of the brown wires at the regulator goes to the fuse block already. Whichever is more convenient for hookup.tahoe healey said:A third choice is the brown wire at the regulator.
Using the same wire gauge as the rest of the circuit (blue/white & blue/red wires) would be OK. I usually go a little thicker 'cuz I'm just that way. :wink:tahoe healey said:Is 14 gauge good enough cause I have brown 14 gauge already?
