Hello all from the Great White North, the Canadian Northern Shore of Lake Huron. I've changed computers a couple times in the winter and lost this site on the way. The site looks a bit different so I hope I'm posting to the right place. The garage thermometer is back in the plusses(yea metric for above freezing the bullocks off the bull)and its time to figure out what happenned to my baby last fall. She's a '76 MGB which began making some unerving clattering noises and lost most of her power, though I could limp her the quarter mile home. I checked the valve clearances at the time and they were okay. I just pulled the head and two sets of valves are real clean and two sets are slightly burnt but the local mechanic says they arn't bad enough to cause the problem. The Head Gasket between two of the sets of valves, on the circle has burnt a space about a half an inch long. The mechanic suspects this but he won't commit himself and says take it to a expert. Of course in a town of ninety-two every one with a pint of bitter in his hand is an expert. I did take out the pushrods and one is a little bent. Is there such a thing as a Little bent? One of the blokes said this would cause the power loss, the noise and the heat to burn the gasket.
Since the head is off I'll take it into an engine shop a few towns down the road and have them check it for cracks and clean the valves. Meanwhile I'll order pushrods and a Head Gasket from the big city. Can I just chenge the bent one or do I have to replace them all?
And why I'm here; should this do the trick or do I have to delve deeper into the engine?
