Powder coat or eurythane [sp?]
Trevor Triumph
I'm replacing the twelve year old suspension bushings. While the car is in pieces I thought I would repaint the suspension parts. I used body paint years ago and the suspension is looking a bit tatty. Powder coat or the expensive eurythane. Any special preparation for that kind of paint?
Trevor
rikiwho123
your talking about the suspension a place that is always going to get dirty ; go to Eastwood and see what tough paints they have ; i used the black rust-o 9.00 a quart and it holds up fine ; good luck.
tomgt6
I would paint just because when powder coat starts to flake off it is hard to match or clean up.
DNK
Match???
Who can see the difference when it it dirty.
PC keeps things rust free, mostly.
And it cleans fairly easy too.
tdskip
I used to powder coat everything but when dealing with springs and the a-arms I've found they can get scratched through the powder coating on assembly, which kinda defeats the purpose.
Darrell_Walker
When I redid my 4A the last time I had everything powder coated, and it still looks great. One big advantage is that it gets a nice blasting as part of the process (I don't have the equipment to do that).
When I rebuilt the suspension on the TR8, I considered power coating, but decided against the expense. I used Hammerite paint (now owned by Rustoleum), and was very happy with the results. I've used it on other things in the past and have found it quite durable. If you go that way, make sure to read the directions, you need to recoat within an hour, or wait 7-10 days. So plan your painting schedule with that in mind.
DNK
You scratch the PC off ,Tom.
Must be a thin PC job.
My guys have hard enough time trying to sand blast it if I make a mistake
Scott_Hower
+1 for powder.
I found a local industrial powdercoater who blasts my stuff and coats it for less than I'd pay to paint it. He uses a polyester chassis satin black - stuff is tough as nails. Had most of the tins/shrouds/brackets done for the Spitfire for $75.
I used to use POR15, but I don't like the high gloss look. Been a while, maybe they have a satin finish. Plus, it always ended up on me, the floor, the cat ...
tr8todd
Hammerite is great for suspension bits. The Rust-o-leum hammered finish chips off. Not the same stuff. POR15 would be my second choice.
tomgt6
I agree that PC would be the way to go, it is just with springs they flex and are more likely going to cause cracks in the PC and at some point peel away. Once PC peels away it gets hard to blend in paint to fix it.
DNK
TRu Dat,just take em off and redo them every couple of years :laugh:
t_lay
If it's pretty much a garage queen, powder coating looks very nice. If you drive it hard - rustoleum satin (out of the can, not the spray). It's tough as nails, and if you scratch it, just touch it up. $10.00 will do the suspension - front & rear. I have a rock crawler jeep - the powder coated bits have not held up to both weather and general abuse (more than a TR would ever see). What's worse is that once scratched, rust builds up under the coating until it flakes off in big chunks. Other than that POR 15 - but it doesn't hold up as well to UV - so it needs a top coat while it's still tacky.
Willie_P
powder coat requires a lot of removal of material to get proper interference fit on machined surfaces etc.
I used a Marine grade etching paint, like POR 15. the only negative is excessive exposure to sunlight (UV rays) can turn it gray (some say). but since this is under the car, that likely won't happen.
it goes on very thin and can be brushed and looks smooth when it dries.
tdskip
lbcs_r_fun said:
Tom: Powder Coating doesn't/shouldn't flake off if prepped and applied correctly!
T
Agree - that was poorly worded. When it gets scratched. Sounds like I need to consider another vendor on for my powder coating...
mtlman8
Trever, If you decide to powder coat I highly recommend Gorilla industrial coating in Tempe. I use them all the time.
Scott_Hower
Every shop I've ever used is well aware of this fact; they use hi-temp plugs and/or tape to mask these surfaces.
T
Trevor Triumph
Thanks for the information. I think I'll go with the powder coat. Taking the suspension apart has been time consuming. I forgot about the interference of the exhaust on the rear a arm. Oh well there is time.
thanks again.
bighealeysource Good match for RENO red with powder coat color Austin Healey 3
J TR2/3/3A TR3 fan powder coat Triumph 3
G Need info on powder coat equipment and books Spridgets 5
svtmikey What type of powder coat system do you use? Restoration & Tools 10
J powder coat prep work? Triumph 22
T Can I powder coat this stuff or will it look dumb? Spridgets 10
T Powder coat or paint front spring pads and arms? MG 37
T Powder coat or paint springs? Triumph 7
B powder coat wire wheels?? Triumph 8
T Will stripper work on powder coat? Triumph 16
angelfj1 Powder Coat Setup Triumph 8
paulpo69 To powder coat or not... Austin Healey 7
fmichaels powder coat Latest Spridgets 21
W Powder coat vs Paint Spridgets 24
I Painting wheels -powder coat vs conventional paint Triumph 13
milemarker60 Powder Coat or POR15 Frame? Triumph 11
R Powder coat front suspension Jaguar 2
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
D Powder coating Spridgets 20
Zimmycobra Powder Coating wire wheels? Triumph 10
Magyar Powder Coating Wire Wheels Austin Healey 19
J Wire wheel prep for powder coating? Spridgets 7
M opinions on powder vs. chrome. Triumph 16
Tr4dude TR6 Tr6 rim before and after powder coating. Triumph 16
Tr4dude More parts renewed with Powder!! Triumph 0
R powder coating Austin Healey 7
Twosheds Powder Blue Club Triumph 14
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
Tim Tucker Caswell Hi-Temp Powder Coating Triumph 1
T So let's talk about powder coating Spridgets 17
A Foot powder finds oil leak! Austin Healey 12
jvandyke Powder coating snafu Spridgets 8
T ? on powder coated wishbones b/f reassembling Triumph 9
Tinkerman Powder Coating Wire Wheels? Triumph 7
S Powder Coating Temperature Triumph 17
S Powder Coating Temperatures Restoration & Tools 5
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
Brosky Playing with powder coating [not me...] Triumph 15
Brosky Powder coating process [stateside, not PR] Triumph 47
T Home Cooked Powder Coats Triumph 22
Brosky Powder coated chassis parts are back Triumph 27
Brosky Powder coating begins next week Triumph 2
Bret Manifolds Powder coating vs. Painting? MG 24
kyreb1862 Powder Coating A Windshield Frame MG 7
beaulieu DIY powder coating , how good does it work ? Restoration & Tools 10
C Car Status and Powder Coating a Top Frame... Triumph 12
F Engine Paint...powder coating or just high temp? Triumph 7
Brosky Plug for Bob Greene of Cape Cod Powder Coating Triumph 5
Brosky Intake and exhaust manifold powder coating Triumph 18
