Folks,
I installed positive-ground LED turn signal and brake lights, and a positive-ground electronic flasher in my positive-ground TR3A.
While everything seems to work, the turn signal lights flicker when the engine is running. It is so minimal, one has to look real close in daylight to see the flicker.
Is this normal?
If it is not normal, could it be possible that the vendor sent me one or more negative-ground light bulbs, or a negative-ground flasher unit?
I ask, because after driving the car a little over an hour (82 miles) on Christmas Eve, the car started missing and I had to be towed back home.
Thanks.
Is this normal?
Thanks.
