I am finally in the process of putting things back together in my 74 TR6 that has been apart since February. Had installed the 14" Moss electric fan as a pusher and it seemed to work fairly well albeit in January in N.E.. Having read many threads touting the benefits of unit as puller set-up I am trying to turn it around with the new radiator (stock TRF) and shroud I am putting in now. As a puller it hits high low or in the middle. Mounted low it will hit the rack and pinion mechanism. Mid height it will hit the cross brace or if I lean the radiator forward the hoses and brace/strut will not fit. If I mount up high by brazing a bracket to the tank a significant portion of the fan will be blocked by solid metal. Please tell me what I am missing here! BTW I do have the Fan Eliminator kit in place.
Thanks,
Elysium
Thanks,
Elysium
