Gerard
JOeyKnapp said:Gerard, is "Blackshell" what you are referring to that you topcoated the Rust Bullet Silver with?
If I have clean metal do I need to worry with any prep other than good primer?
Also, it seems that your PM box is full. Is pixelsmith@gerardsgarage.com still a good contact email address for you? I need to find out about your Master Cylinder rebuild/resleeving.
thanks.
Hi Joey,
Yes, Blackshell is what I used.
Most paints are porous. I think the paints that are formulated specifically as a barrier are a good idea, especially in cases where metal is not new and has rusted at some point. I've experimented with a lot of paints before and found that many, even when the surface looks good, will begin to rust underneath before long, even in fairly protected environments. I'd check the test result they demonstrate and decide for yourself. It might be overkill or it might be good insurance. I've found these couple have performed well for me. That's about all I can tell you. There are a couple less exotic paints in spray cans I like too, but they don't have the chemical/solvent resistance or hardness of Rust Bullet once it's cured.
It's fine to email me direct at that email address.
Hi Guest!
