Points assembly order of washers
steveg
I bought some points and condensers from Distributor Doctor. Rather than having two "hats", they have a single hat and two fiber washers. The larger one almost fitted over the stud base; enlarging the hole slightly did the trick. The smaller one fits over the stud itself and functions as the other hat would, keeping the spring away from the grounded stud.
I can't see any need for the larger washer. In my pic it could be as easily left off. Anyone know differently?
Duh - answered my own question - the larger washer goes under the rubbing block on its post.
pkmh
Steveg,
I am not savvy when it comes to electrical, but I recorded what I presently have as a points setup when I purchased my current Healey just over 7 years ago.
I always refer to my drawing when I change my points or perform a complete tune up. And I am only using my setup since it hasn't done me wrong before, so, I don't bother trying to be creative.
Not sure if I do have a secondary washer as you show. I'd be curious to know if what I show is, in fact, correct or appropriate. But, again, I never had any issues of any kind so don't fix what aint broke?
Paul
LarryK
I left the bottom insulator off once on a Jag, took me a few hours to figure why it wouldn't start.
Keoke
Steveg,
Paul
IT appears lik the required bottom insulator { WASHER } is there U just did not identify it on your drawing?
roscoe
I am in awe of being able to draw so well. My chickens can scratch better than i can draw.
pkmh
Keoke,
OK, I think you're right. I didn't identify that particular washer and below that, a "do-hicky" cylindrical piece I will now have to go back and identify again.
Keoke
Keoke,
I recons so coz with out it you would have been in the LARRY K crowd-LOL
pan
Paul, nice drawing. A man after my own heart! I was in Melbourne a few years go after attending the Phillip Island Historic races. I had to replace the points before heading home but in haste I assembled them incorrectly and I had no spark. Took a while to realise my error! I now carry a diagram showing the correct method. Every time I fiddle with the points I remind myself that I once fitted new points in the middle of the Nullabor Plain with a wind howling, uninterupted from Antarctica!
Cheers,
Alwyn
steveg
steveg
The takeaway: the spring with moveable point is an electrical connection from the primary wire and condenser to the grounded point.
Therefore there must be no grounding before the current gets to the points.
pkmh
Pan,
Quite an experience to have that happen on the Nullabor Plain, from what I did a bit of research on. Were there any camels nearby watching over you during the repairs or possibly one be available to offer a ride in the event you couldn't be on your way?
Just curious.
Paul
pkmh
That's one "Point" well taken. Thank you for that!
pan
Paul,
I'm impressed that you took the trouble to look up where in the world the Nullabor Plain is! I was on my way home from Perth in Western Australia. From Perth to South East Queensland where I live is similar (I am told) to Los Angeles to Washington. Plenty of signs saying to look out for camels (as well as wombats, 'roos etc) but I never sighted a single one.
Cheers,
Alwyn
pkmh
Paul,
Cheers,
Alwyn
Ok Pan,
I'm equally impressed if not more how you managed to survive your ordeal on the Plain. Same goes for those camels...
...for the name of that region might escape me from time to time but learning how camels were abandoned after using them in the completion of the 'Railroad' there, (thinking they would just die off given the existing harsh soil conditions, etc.), only to thrive in numbers later...Well, those camels, with their survival skills...All I can say is, I'm quite impressed!
C TR6 Seatbelt anchor points Triumph 2
L T-Series Back to org. points MG 3
P TR2/3/3A NO spark at points Triumph 36
drooartz Bugeye jack points to remove rear axle Spridgets 18
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
W Seatbelt Anchor Points Austin Healey 2
T TR2/3/3A bad napa points Triumph 9
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Disributor Points Triumph 3
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
T TR2/3/3A tr3 points& condenser#'s Triumph 6
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
K TR4/4A Distributor Points and condensor insulating washers..... Triumph 14
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
R TR2/3/3A Ignition points Triumph 3
R Ignition points Austin Healey 21
doc50 TR2/3/3A Question about points. Triumph 6
C TR4/4A Sudden loss of points gap Triumph 10
B TR2/3/3A Vent cowl lid mounting points Triumph 3
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
S Points versus Pertronix Spridgets 22
Michael Oritt MGB MGB gearbox identification points MG 1
C TR4/4A Burning through points Triumph 4
RedTR3 TR2/3/3A Best Ignition points set? Triumph 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
TomR 1978 MG Midget with Points Distributor Spridgets 4
AUSMHLY Pertronix or points Austin Healey 49
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
Jeepster BJ8 exhaust mounting points Austin Healey 17
S Original Lucas Points Austin Healey 4
Marvin Gruber New points problem Austin Healey 1
nevets Points failure - broken cam follower Austin Healey 3
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
tri_carb_healey brake drum work, proper jack points Austin Healey 12
drooartz Pertronix back to points MG 28
lbc_newbie Best anchor points for shipping a Midget Spridgets 8
K Those who switched back to points from petronixx.. Triumph 64
G TR2/3/3A TR3 Grease points Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
Ken40 MGB-GT 67 B/GT unibody datum points MG 0
O TR2/3/3A Best jack points/location stands TR3 Triumph 4
