Plug Your Pipes!
HealeyRick
Those of us who store our cars over the winter know how much damage mice can do and their ability to get into the tiniest of spaces. I found a big nest in my heater box this spring when feathers started coming out of my defroster vents while driving. Hard to believe how much rice the little beggars stored in the cylinders of this Healey by traveling up the tailpipes.
LarryK
I always use the copper brillo pads cut and put in pipes. I used to work at a Jag shop and customers would tow in there precious toy because of no starts. Fire them up, shoot dog food, baby mice, string, all sorts of stuff. Would back into bay to bare wall. Wall stopped everything, instead of having to clean shop. Found dead mice in brother in laws cabin filter box, stopped them from going in core. Another brother in law couldn't figure his loss of power and bad fuel consumption in a MINI, mouse nest cover 90% of intake in filter box, filter stopped them from entering intake.
nevets
Never had mice in my exhaust system but after storing my Healey in a heated garage for over 15 years, I just discovered that a mouse got into the interior and did some damage. The critter entered through the hand brake opening in the fiberglass transmission tunnel from under the car, chewing through the leather (vinyl?) gusset that is part of the tunnel carpet. I set a trap in the car near the hole and caught it within a day. Hopefully there will not be others? I'll need to make a patch to cover the hole and seal the opening in the tunnel with some stainless steel wool. I avoid bringing any kind of food or snacks into the garage to avoid attracting mice, but I guess they must like leather.
Jack T
I just watched that video the other day. Unbelievable. Have never had an issue (knock wood), but will be using #3 steel wool from now on.
LarryK
They like to chew leather and vinyl, rubber helps keep teeth in check and they love the seat stuffing and the holes they can nest in behind the dash. I have stripped my MK1 done for blasting and I found a football size nest behind the glove box with another cavity full of acorns. Never rattled when I drove it, then parked in barn for 5 yrs.
Guido36
A warning here: If you find rodent droppings steer well clear as they may carry hantavirus. Hantavirus shares several characteristics with Covid-19 including shortness of breath, lung damage, fever and other unpleasant symptoms such as renal pain and damage, urinary tract infections, dizziness. It has been reported that between 36% and 38% of people who contract it die from it. Do not disturb, sweep, vacuum, stir up the droppings in any way as the spores become airborne and are highly contagious. The only way they should be handled is by picking them up carefully with a damp cloth and disposing of them in a sealed plastic bag. Only do so if you are wearing PPE - N-95 mask and disposable nitrile gloves. I say this as I have contracted it on more than one occasion - despite taking what I thought were adequate precautions. Symptoms have started with a spacey feeling and echoing in the head followed by a blinding headache, muscle pain, kidney pain, burning and passing blood when urinating and a high fever with chills, shivering and burning up. I have spent 24 hours plus curled up in a fetal position riding out a fever of 104 degrees. Please do not mess with the droppings and do not take any risks.
https://www.cdc.gov/hantavirus/hps/diagnosis.html
https://www.medicinenet.com/script/main/art.asp?articlekey=229363
pkmh
Thank you Guido for that advice.
And I saw that video the other day. What a mess those mice made of that engine! Plugging the exhaust pipes sounds good but I have to place a reminder somewhere or otherwise, I will attempt to start her forgetting the plugs are in place.
Madflyer
I have heard dryer sheets keep them away any body else know of that?? I have an ultrasonic unit in my garage have had no problems. Something to try also. I think barns are the big problem a friends Lotus lights did not work they ate most of the wiring in barn over winter. Madflyer
glemon
I work with a gal who lives on an acreage in the country, now that I have my mini acreage in a wooded part of the city, our discussions sometimes turn to critters. She and her husband, a mechanic, have lots of vehicles. She swears by the Bounce dryer sheets, says never a problem since she started using them, wipe it around leave them in the car.
pdplot
Worst problem I've had is when my '84 Audi Quattro was outside. Mice got in, chewed up the wiring and it wouldn't start. They jumped up inside because it was warm under the hood. It was fall as I recall.
Deleted member 21878
my shop is not that old but i also keep glue boards at each end of the O/H door. they catch a lot. need to keep the mice out to keep the snakes out.
twas_brillig
We've got mice in our garage somewhat year 'round, but especially in late fall/early winter. I've used electronic mouse traps fairly successfully, but I've been disappointed in their reliability/durability - but will continue with them.
We have access to a barn and - if I end up storing a vehicle out there - I'll order an indoor Car Capsule, as we've had really good success with their outdoor model. If you live north of the 49th and are thinking of purchasing one, talk to them about shipping as their preferred courier service costs about ten times that of the putting it in the mail. Doug
A word of caution about "baiting" traps. They actually attract critters. They love peanut butter and will find a way to get in to feast. I use the Bounce dryer sheets stuck into the bottom spokes of each wheel (if you forget to remove them, they magically disappear as you drive). If I am not going to drive for awhile, I rubber band to attach a baggie to each of the exhaust pipes. If you forget them, the just blow off. (yea, I am old and forget a lot)
John Turney
I don't think dryer sheets will stop the bears. Fortunately, though, they can't fit in the exhaust pipe.
But the bears would be soft and fluffy. Have you seen what they can do to cars? I think the wiring would be the least of the problem.
C MGB New plug wires and distributor cap MG 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
PAUL161 T-Series Odd spark plug encounter! MG 10
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Spock TR6 Transmission Plug Triumph 4
D TR2/3/3A Plug Leads Triumph 12
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
K TR2/3/3A Testing spark plug wires..... Triumph 11
B TR4/4A Oil Drain plug size Triumph 14
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Expansion plug question Triumph 5
M Sump Plug Austin Healey 26
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
drooartz Leaking 5-speed drain plug Spridgets 26
J TR2/3/3A Oil drain plug stuck Triumph 10
S Bugeye Radiator Tank Plug Size? Spridgets 24
K Numbered Spark Plug Boots? Austin Healey 27
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
R Plug gap for 907? Lotus 4
Lin Rear differential drain plug leak Austin Healey 16
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
warwick-steve Magnetic Gearbox Drain Plug Austin Healey 28
K TR2/3/3A Plug Weld CyL Head Triumph 10
T TR4/4A Core Plug - Cam Rear change Triumph 7
JimLaney Rocker shaft plug/screw delima Spridgets 3
T Balance Plug Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
F TR2/3/3A Plug Checks Triumph 17
