Please help! turn signals.
This is really sounding like a bad ground to me, too.
Here's how it works: Suppose your turn signal and sidelight bulbs have a common lead to ground, but that ground is bad. Current from the turn signal will then go back through the sidelight bulb and find its way to ground through a combination of the tail lights, license plate light, and maybe even the panel lights. Since the current splits between all of these bulbs, there may not be enough to light any one of them. Or, you might see a dim glow in some.
You can follow this on a wiring diagram.
To find the culprit, measure the voltage between the grounded side of the turn-signal bulb's socket and the chassis. Obviously, this should be zero, but if not, the ground is bad.
