As some of you know, I pulled the head off my TR4A and decided to replace the pistons and liners. I've had some good help from several folks here, including a cautious suggestion that I use PlastiGage on the connecting rod bearings. I did, but now I'm puzzled.
The bearings show .001 oversize, but using PlastiGage shows that I'm under the spec clearance by about .001.
The spec clearance for the connecting rod bearings in my manual reads .0027, and the allowable play is .005.
PlastiGage says my clearance is barely .001.
Is there a trick to using this stuff, or do I suspect someone put oversize bearings in the engine but didn't cut the crank. I can't imagine that.
I checked all four bearings, and all appear below spec. One nice fat PlastiGage line, well over 1/8 inch thick. Squished out in sort of an oblong fashion.
My oil pressure has always been a bit high, like about 75, and even after warming up it stays around 60.
Any ideas here?
I want to order new bearings, but I can't 'till I figure this out. Three of my four sets of bearings are near perfect. One looks like some grit must have come thru the oil galley, because the middle of it is deeply scared. The crank is only slightly scored on that journel and not enough to warrant yanking the crank imho.
[BTW, I know I need to change the silly "handle" I use. Been too lazy. It's a small town in Nova Scotia where we're from, and "Hound" was either me or our golden retriever we had, whichever way my brothers felt at the time]
Any ideas here?
