We have recently started carrying the 89mm Piston and Liner Kit for the Triumph TR3-TR4A Engines. This is the biggest kit that you can install without boring the block in your car. Each liner has been reinforced with a 2mm thicker body for more strength and greater stability. For the pistons, they are a short skirt design making for lighter weight and less drag, plus each piston has drilled oil return holes instead of oil slots for greater strength. To keep the weight low, each piston pin has been tapered bored to lighten things up, yet have strength where it is needed. With each liner being bored to match the piston, fitment and correct clearance will be assured. The kit comes complete with Pistons, Liners, Deves Rings, Pins and Clips. Piston and Liner Kit 89mm Click here for a link to our web site to see a picture of the kit. Any questions please let us know.
