I've done this . You don't need special tools . This was all functioning together at one time yes? And now just the pinion brgs are bad? The pinion depth is set by a spacer under the inner large cone, and the ring gear backlash set by shims inside of the carrier bearings , all set at the factory with new gears and brgs. and fit to a housing. Since bearings are made to very close tolerances , replacing the brgs. only will put the gears back to where the factory set it up initially . It won't make your gearset noisy where it wasn't before. Factor in some wear and all you're likely to have by not changing anything else is excess backlash which won't hurt anything. With that said , its critical that when you fit the pinion ( without a seal , slightly oiled brgs., original center spacer and shims), you feel a slight drag when spinning the flange by hand. This is the preload. A slight drag as opposed to free spinning. Thats it , you haven't changed pinion depth from factory set up so gear pattern will be the same. If when you've assembled the carrier you feel you have too much backlash then adjust that by moving shims under the appropriate carrier brg to move the ring gear closer to the pinion. You can paint the gears with white grease and inspect the drive side ring teeth pattern to be sure. Of course it should be dead quiet when turning over by hand too. Don't forget to install a new seal on the flange. I use an air impact on the pinion nut. Remember if it was easy to put a Healey " right" everyone would have one. Kevin
