Here are a couple pictures of my alternator installation. Mazda rx-7 unit, a 6 inch piece of brass pipe, Mr Gasket chrome Alternator swoosh bracket, and a fan belt 1 1/2 inches longer than stock. Seemed easy. /ubbthreads/images/graemlins/cheers.gif
Looks just spiving from this angle. Not able to discern the method/widget to keep the brass pipe from moving forward from the photo tho. Spacer onna back at the bracket? Just curious.
Sid, I was looking at one of the RX7 alternators last fall on a friends racer. Now I think I just may give it a try. He's got a box of the things I can pick from. Thanks for sharing.
Jeff
da spacer onna da backa da bracket is... because a seven inch bolt is tooo short and an eight inch bolt is about dat much tooo long... so I putta da spacer in dere to keeepa da bolt from hittin da belt.
