pics of my bt7
A couple of additions to your list:
6. Take tons of photos before and during disassembly so you know how it goes back together. Although Randy and Andrea have lots of great photos, you need to have your own. You can't take too many, especially with digital cameras.
7. Label EVERYTHING as you take it off.
8. Store related parts together.
9. Record where you put them. Nothing more frustrating than knowing you have something and not knowing where it is.
Mine started out just about where yours is, but with no holes in the doors or fenders. I didn't want to take off the shrouds either. It ended up looking like this after the first round of painting at the body shop:
Hi Tricarb,
Well, so the cancer is deeper than originally thought? At least yours is running and the engine compartment looks great. I have a few suggestions too, which may help:
1) there is a video sold by the Healey Center in the UK that will give you insight on what a full restoration of one of these looks like, done by specialists in the field. It is quite informative and well done. I paid 20 bucks for a copy on ebay some time ago, but unfortunately loaned it out and haven't seen it since (or I'd offer it on loan).
2) I bought and still use the MIG sold by Harbor Freight specifically to do my healey. It is a very basic unit, made in italy, with low output. It will only do sheet metal, will overheat if you try to weld too long of a bead, and the heat only has 4 settings. I normally keep it on high only. That being said, it has been reliable, is still working now, 10 or so years later, and I do use it often as it is easier to set up than the TIG, gives a better looking weld than the arc welder, and doesn't spread the heat like a gas welder (I do have all these too - aquired along the way with the Healey rebuild). If I were to do it again, I would get the small MIG by Miller. They have great support, are sold and serviced locally, and are a quality machine. The TIG I own is a Miller (the small, hobby version) and I'm very happy with it.
3) If you choose to take on this work, it will be a long journey but you will learn alot along the way. If I were to do it again, with a car in your condition I would seriously consider taking it to a shop for the metal work, if you can find someone with the skills and experience needed. I had my front frame member replaced along with other bits by a specialist in southern cal, and was never sorry for it. He aligned the frame, did the replacements, and all with excellent results. Unfortunately I ran out of cash and had to take the car back before he did the fenders, sills and rockers. So I had to replace those bits. What a chore!! And figure you'll have to do things twice at times as you are learning. Everyone I talked to recommended the Kilmartin panels for replacement, and they worked out well. They are slightly thicker metal than original, but the curves fit well with minimum 'sculpting' to weld them in. Sheet metal is a bear to weld since it warps so easily, and there are long flat sections in the front fenders where the rust repair panels fit. The video by UK Healey Center shows them soldering on the rust panels after flanging them. This is probably a much easier way to do it than the welding. You end up with a straighter panel in the end, but perhaps not as well rec'd by the purists.
Be aware too that this isn't a car like others. All panels were semi-custom fit at the factory and even new panels need fitting. If you do take it to a specialist, he may do the repairs without removing the fenders as fitting the repair panels often requires the other panels in place to ensure a good fit. Once tacked in place the panel can then be removed for final welding and body work. Keep the engine and drivetrain in the car during these fittings so the frame will be flexed into the proper position. The doors can flex up about 3/8 inch in some cases between having the engine/etc. in place vs. not.
4) It will cost 2 to 3 times what you originally estimate. That is a given, even if doing it all yourself. If you take it to a specialist for the metal work, you can still do the time intensive body filler, paint prep, etc. and then send if off to a painter. That could save you alot of $$. I am about to send mine off for final paint, and was quoted $2500 for finishing it with a Dupont paint system. Don't use POR if you can avoid it. Get the rust either blasted or totally removed. And if blasting, use a very fine mineral type blasting, and coating with epoxy primer. The fine mineral material is small enough to get into the pin holes created by the rust, doesn't warp sheetmetal, and the epoxy primer adheres excellently to the metal so the paint won't chip. Use a paint 'system' too, sticking with the same vendor's products so it all will work together....
Well, good luck with your project. I'm envious of you having a car in such good condition from which to start. Just don't get discouraged. In doing this and other projects I've found that if you do something on it, every day, no matter how trivial, will keep it going and in your mind and progress will occur.
Jerry Rude
10 years into a 3 year restoration
Brinkerhoff said:
Its obvious you ( and many of the posters here) have no idea what you are getting yourself into . Please wait until you have a friggin clue as to what you are doing. Don't take it out on the car.
In the immortal words of Sgt. Hulka, "Lighten Up Francis"
TCH is a young guy with his first Healey trying to do the right thing. He's going about it the right way, asking for advice from the guys that have been there before. Don't scare him away. Be happy there's someone under the age of 60 that thinks Healeys are cool. If you have a constructive comment for him, make it. Otherwise, he's going to think we're a bunch of cranky old farts. (OK, we probably are, but we don't have to let him know it).
its difficult to properly word things when typing in a hurry. im sure brinkerhoff was under the assumption that i'm going into this tommorow w/o planning or prepping. i'm well aware that this is an austin healey and not a civic hatchback. i ask these stupid questions to learn more stuff from the "council of elders" and i supplement that with research and my fellow british car club guys down here are more than eager to work on a big healey. right now my plan is to read the crap out of the restoration guide. and try to jest get the doors rust free. this is just a small start. everything i do will be posted here beforehand and also to my car club. like i said im not trying to tear my whole car apart just quite yet. for example, ive placed an order for miller mig weld machine. that will be sent to my friends house so he can start playing with it. keep in mind next summer is when i plan to actually break down the parts of the car that will need work. so he'll be ready. and with everyone's help so will I
P.S. I dont mind the flames, most of the time its meant to keep me from doing something stupid. If any of us here didnt have thick skin we wouldnt have healeys.
will post pics of stripped interior soon. hopefully thatll give us a better idea of my project. i'm part of a legacy now so the healey stays with me!!
baby steps, baby steps. the idea is a rolling resto this time around.
btw thank you guys. these posts are already taped to the garage to remind me to get legit!
HealeyRick said:
... Be happy there's someone under the age of 60 that thinks Healeys are cool. ....
+1 :cheers:
It's easy to go to far, the hardest part is knowing where to stop (and go on the next day :yesnod: )
Hey Tri,
Good for you. Take your time, study, ask questions, take input from those that try to discourage you, but do it right and don't be afraid to do it yourself. That is the way we grow as individuals.
