Wedge PI fuel pump specs
sd80mac7204
Anybody know what the stock GPH/LPH flow rate on the in-tank PI pump is?
The fuel pump for fuel injected Wedges (both TR7 and TR8) are not in-tank like the carb TR8 is (the carb TR7 uses a mechanical pump).
So SD, taking Darrell's response.
What version you need?
My mistake. PI inline pump it is.
If it's a V8 then it really doesn't matter as long as it i higher than 45
The regulator keeps it in check.
I can't find any specs on the pump, but here are a couple of cross-references, maybe you can get specs:
AC Delco EP181
Bosch 69414
Thanks guys
