dklawson
Is it relatively simple to find the url of a photo so it can be shared on a web page? I opened one of your photos, copied the url, but it was a very long string of numbers and letters which didn't end in jpg, png, etc.
For example, I tried adding your photo of Ford carb floats, but the BCF image box said "invalid file type".
Thanks.
Tom M.
They (Google) don't make it easy to post direct links but I found the workaround. In the case of the Ford carb (actually fuel sending unit) float, there are two strings you need to paste together to form a valid direct URL link. I found the following method works.
First you need the path to the page where the file is stored. In this case: "https://www.sites.google.com/site/purlawson/home/pictures"
(copied from the browser address bar).
The second/last part of the URL is the name of the photo itself. In this case: Floats-Smiths-n-Ford.jpg
This is copied from the Google site list of files on the page mentioned above.
The two strings are pasted together to form the complete string...
"https://www.sites.google.com/site/purlawson/home/pictures/Floats-Smiths-n-Ford.jpg"
That string is then pasted in the URL tab of the the image link shown on this (or other) website's editor. I have never been able to open a document from the Google site, copy its address, and paste a functioning link. As you said... the link is long and unreadable. The workaround I found is cumbersome at times but once I figured out the trick it works well enough.
