Keoke
Re: Petronix - Pros & Cons
OK Vping, while not desireable the rotor is safe for now.If you have some super glue handy put some in the void behind the brass contact and push it all the way back-Towards the top of the screen-. get a new one soon. With the engine Idling. line up the timing marks using the dial on the back of the timing light. Watch the alignment of the timing marks while the engine idles.If the mark on the damper jumps around there is wear in the DIZZY.---Fwiw--Keoke
Hi Guest!
