Hello everybody
I am at my wits end and hope I can get some help.
I have a 1960 BT7 which originally came stock with a positive ground. For all the years I owned the car (11 years), I assumed it was still positive ground. To make a long story short, I discovered my Healey had a neg ground after I bought my Pertronix parts (pos ground). So I switched the battery around and made the positive the ground. The only other thing I did was reverse the wires of my electric fuel pump - seems to be working.
My distributor is a DM6A. I bought a Pertronix ignitor for a DM6 (I did not see a listing for a DM6A in any vendors listings)to replace the points setup. It is a Ignitor Positive Ground LU-165P12. The coil is Flamethrower #40511, it replaces my Moss Sport Coil.
The instructions for the wiring seems clear and straightforward. I believe I have wired it right.
I connected the positive terminal on the Flametrower Coil to a ground. Per instructions, I connected the Ignitor B/W wire to the neg terminal of the coil. I connected the Black Ignitor wire to the White (hot)wire. The coil now only has 2 wires connected to it (as it should per the Pertronix instructions. My original Sport Coil had 3 wires connected.
The white wire with Black stripe is now not connected to anything. My wiring diagram says this wire connects to the kill switch next to the battery. Can I connect this to the coil positive??
Now here is the problem. The car cranks and I can keep it running (although rough) only if I keep my finger on the starter button. As soon as I take my finger off the starter button,it dies.
Any suggestions on how I might proceed? I thought I would query this forum before I am forced to go to someone who knows what they are doing.
Thanks
Bill L
Thanks
Bill L
