Hi Skip, this will depend on the type spark plug you are using, the compression ratio of the engine and whether you also included an aftermarket coil [Pertronix/Lucas Sport] along with the Pert module. As a general rule with a high compression engine and a high out put coil you can increase the point gap to about 0.035". For a stock coil I would not exceed 0.030" gap. However, in this latter case a stock point setting will be OK too.--Fwiw--Keoke
