BJ7archaeologist
Fellow Healeyoids, I'm in the process of hooking up a Pertronix Distributor on my 63 BJ7. My Healey was running fine on the old points. I burned out or it was bad to begin with the first Pertronix distributor I installed one month ago. I have a rebuilt unit now.
Here is my question, my car has been converted to negative ground, that is for certain. I also have an alternator. I have new Bosch plug wires that are not solid core wire but carbon fiber as per the instructions and a new Pertronix coil. It is only two simple leads, one to the neg and one to the pos of the coil. Easy! Now, which way are the wires to go from the harness with a neg ground car to the coil? Does the B/W lead go to the pos or the neg? The solid white wire will go to the other terminal then. Thanks!
Randy
63 BJ7
60 BT7
Randy
63 BJ7
60 BT7
