Had a friend install the pertronix kit and high performance coil. Car starts much more easily. But I have noticed a ping and some loss of power as the car started running hot as in over 210 degrees when it never went over 190 in the past. So I tested with a timing light and noticed the hash mark at 12 oclock or at the top of the wheel when I started up the car. Adjusted the distributor a touch counter-clockwise, idle reduced and the hash mark is further away at 1 oclock. Have I retarded the ignition? That was my hope as I've read that may reduce the ping.
What is the correct adjustment position and is there a reference guide on this? My Healey manuals don't seem clear on this.
Thanks,
Eric
Thanks,
Eric
Hi Guest!
