Howdy all,
Trying to "reanimate" a long term hibernating '68 sprite. PO had gotten it seductively running at time of purchase, so I know it ran. (It's got heinously home-made wiring setup tho'... /bcforum/images/%%GRAEMLIN_URL%%/cryin.gif )
In quest of reliabitly/peace of mind I aquired a Pertronics electronic ingnition adapter (under rotor cap type). I've installed it and have some questions. Modules black wire is attached to lucas sport coils negative side and red wire is attached to coils positive side per the instructions, but what/where else is to be attached? Obviously I need a hot wire energizing the coil right? Haynes wiring schematic shows a (presumably hot/positive?) wire coming from back of Tach(?), But my original (very shade tree wiring) setup (back when running) had a (hot?) wire going to the negative pole on the coil from the ignition switch(?)- Which is NOT shown on the Haynes wiring diagram...
Now I have no/zero spark coming from distributor and was wondering if you Gents could offer any advice?
I have tried only having the wire from Tach going to positive terminal on coil (with any thing other than Pertronics on negative disconected). and,
Only having the (extra?) wire from the egnition to the positive terminal on coil (with any thing other than Pertronics negative disconected). and,
reversing the above. and,
having both wires attached and alternating their (pos/neg) attachment/orientations.
No spark.... What should I do now? Have I fried the Pert? /bcforum/images/%%GRAEMLIN_URL%%/eek.gif Is there anyway to test it?
Thanks in advance! /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
Edward
Edward
