TR4/4A performance cam
nbailey
My recently acquired 67 Tr4a came with a sportcam installed. The previous owner does not know
what kind, or what valve clearances to use. Does anyone have any suggestions where I should start
when setting valves? Thanks
tinman58
I have a mild cam in my Tr3 and the valve clearance is .12 . I think you would be safe at that number.
KVH
I've got a 66TR4A I bought a few years ago. It has some kind of modified cam. Some old notes from the prior owner say the cam is from Ken Gillandere at British Frame and Engine, Ryland Avenue, Temple City, CA. Notes I have say that the Exhaust Lash is .018 and the Intake Lash is .016. The Duration for each is 260.
Then I have a graph with those specs, and the graph says "Data for Degreeing Cam at .050 Tappet Rise," and that graph shows durations of 214 with no information about valve lash. Not sure what the graph is telling me, although is says the intake valve opens at 37 degrees and the exhaust closes at 37 degrees.
Do I use the .016 and .018 for the valve clearance when adjusting the tappets--instead of .010? Seems a bit extreme for variation. By the way, would this explain why this car is fast off the line but seems to top out quicker at high RPMs than my plain stock 4A?
Below are copies of my specs and graph.
TR3driver
Great Pumpkin - R.I.P
Should be the other way around, running the lash too tight will emphasize high end power a bit, while cutting low end. My guess is that you have tired valve springs instead, or maybe some kind of exhaust restriction (like a collapsed baffle if you have baffle type mufflers).
And yes, I would at least start with the lash spec for your cam. The best lash depends on cam lobe design, which is exactly what changes for a 'hot' cam, so the recommended lash for any particular cam has little to do with the factory spec. Or if you want, follow the information at https://www.tildentechnologies.com/Cams/Tip_Lash.html and choose a value yourself :smile:
MDCanaday
The answer is it depends......on a screamer .015, for the street .012 is better. The racer needs
the oiling on the cam face at high speed and cares little for longevity. you should do well at .012.
MD(mad dog)
B TR4/4A Performance cam Triumph 24
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Dadandson Stock Cam VS Performance Cam Spridgets 1
Number_6 TR2/3/3A TR3 Performance cam from BPNW Triumph 6
PeterK TR4/4A TR3-4A Improved Performance Cam from Moss Triumph 3
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
C Abingdon Performance Ltd. MG Classifieds 0
90dog Classic Car Performance Reviews Austin Healey 5
R For Sale TR6 Parts huge collection and Engine/Performance Parts Triumph Classifieds 0
Michael Oritt Towards better brake performance.... Austin Healey 28
M Leaky Fuel Pump and Weak Performance Spridgets 14
Lin Advance Performance Technology [APT] - Great customer service Austin Healey 1
M TR2/3/3A Brake System Performance Expectations Triumph 27
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
B Performance coil Austin Healey 10
Rut TR4/4A Performance engine rebuild Triumph 3
B Poor Performance Austin Healey 20
sim High performance DCOE carbs 40 or 45 Spridgets 5
J General TR Let's Talk Timing a TR2/3/4 for Performance. Triumph 6
J US Performance parts Austin Healey 9
NardisCNC Performance alternator questions.....?? Spridgets 14
Hap Waldrop VTO Performance Wheels, Spring Sale Spridgets 13
Hap Waldrop VTO Performance Wheels, Spring Sale MG 1
Hap Waldrop VTO Performance Wheels, Spring Sale Triumph 9
I Effect of bad valves on engine performance? Triumph 9
CZ_Dave Performance Experiment, Will it work? MG 11
I TR6 TR6 performance help Triumph 10
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
B 85 jag XJ6 improve it's performance ? Jaguar 4
JPSmit Performance World Car Show Spotted 10
rick_ingram MG2011 - Autocross School/Performance Driving Scho MG 0
steveHealey3000 Originality versus performance Austin Healey 38
Don_Racine We're Spridget Performance Specialists! Spridgets 3
JPSmit Performance World Car Show Other Cars 1
Hap Waldrop Performance Challenger alloy wheel MG 0
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
M MGC MGC Performance Exhaust System MG 11
lbc_newbie Rebuilding 1275 for a little performance... Spridgets 8
Tabcon Performance upgrade plans and an SU question. Triumph 8
W Monza Performance Muffler Spridgets 65
B 1275 performance books Spridgets 7
B performance increase from triple strombergs?? Triumph 33
tweety pulling catalytic conv... better performance? Spridgets 3
C Performance Modifications Triumph 3
kodanja Cold weather Effecting Performance? +- Triumph 35
John_Mc Wedge Wedge performance questions Triumph 17
RickB Dynolicious performance meter for iPhone MG 0
Gray_Cat Spridget Performance Parts Spridgets 3
bluemiata90 Wedge TR8 PERFORMANCE INCREASE Triumph 17
