Perfect timing Paul/Alana
T
Tinster
I'm gathering a head of steam to replace my fuel delivery
system from the carbs rear ward.
<span style="color: #FF0000">BLARGH- a 2nd time!) </span>
Paul's fantastic gift of a Rego Reconditioned OEM
fuel pump arrived a few weeks ago and now Alana's great
gift of fuel line fittings has been delivered. I don't
know the identity of the brass Tee shaped piece.????
My health's not so high level of late, so this is going
to be a real slow project.
Thanks you Paul and Alan both!!!
dale
It's a splitter - I was running twin delivery systems at one point. I figured if all else failed you could use it for the two carb takeoffs, or just take out the connectors.
You don't need to replace the entire fuel system. Your problem is in the tank. Fix that and you'll save a ton of time, effort and ~future~ headaches.
