Invert the plastic bottle and squeeze the contents into the steering box . Run the steering box through its travel so the lube settles and add more .
Would a Turkey baster work?
David
It can't be hard I just did it to my TR3's box. The Penrite bottle I used had a clear tube dispenser inside of the cap.
No clear tube dispenser in the bottle I bought. Guess I'll have to improvise one.:chargrined:
Heat it in boiling water. Then it will pour more like a fluid.
If you have the top off the box, I would suggest not moving the steering wheel because the shaft can pop up and off the worm gear.
