I suspect there's a limit due to piston travel requirements.
The accelerator mechanism is a Rube Goldberg arrangement of levers and shafts; just getting it in 'standard' configuration is a fiddle. If you lowered the pedal, you'd have to assure you could still get full opening of the throttles. A cable-operated kit might allow more adjustment with full throttle plate travel.
