I agree with your mod. I did the same mod.AUSMHLY said:The only modification I did was to replace the factory fluid activated brake switch with a mechanical switch, which presses against the break pedal arm. The mechanical switch can be adjusted to activate depending on how much travel is applied to the break pedal. Once set, it's problem free. More reliable than the fluid style.
Hi Guest!
